Inherit operation not supported for exploded views
I'm getting this notification when updating drawing sheets that have exploded views on them.  With view updating being as ridiculously slow as it is for large assemblies, I like to update the whole drawing while I'm gone for lunch.  However, this message pauses the view update process.  Any way to prevent this from popping up?
______________________________
NX 11.0.2
Tc 11.2.1
1 REPLY
Re: Inherit operation not supported for exploded views
I don't think you can disable the message, but you could try disabling interhited PMI in the View Settings of each of your Exploded Views to see if that helps prevent the message (assuming it's this setting that causing the message):
Regards, Ben
