Internal error: memory access violation
Hi everyone,
I am not able to find any possible causes for this error.
Two of the cases when I faced this are:
  1. While opening a part file: Error occurred during display of part.
  2. Other one showed up during tool path verification, while generating IPW.
What could be the reason for this?
Paras Raina, Technical Head, MSC Systems Pvt. Ltd. (India)
NX 12.0.2
Solid Edge 2019
Re: Internal error: memory access violation
i think that it is better to log a call at GTAC for this one.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
@ruud_vandenbrandWill do tomorrow. I just thought that our wonderful community must be having an answer to this.
Anyways, thanks for the suggestion.
NX 12.0.2
Solid Edge 2019
Hi @Paras_R,
"Internal Error: memory access violation" is a generic error message.  Your NX log files might give you a better understanding of the cause, but better to have GTAC review your logs (as they can extract more information and consult with development).
Regards, Ben
@BenBroadThanks.
They are the last resort always.
NX 12.0.2
Solid Edge 2019
