Is it possible to create a color map on the face such as wall thicken analysis by NXAPI?
It should be split the faces to partitions, is it a good way to use facet body ? we can get the vertical values , but the there are no face tag for the partitions.
who knows the methodology of the Wall thicken analysis function?  does it use finite elements to divide the object ?
Any good suggestions, please advise.
Thank you.
Re: Is it possible to create a color map on the face such as wall thicken analysis by NXAPI?
The wall thicknes tool is not using any mesh so far i know.
It just place a ball between the surface limits and measures there the diameter of the ball.
The ray techniek is by pointing a arrow (vector) for the face normal untill it intersects again with a face and measure then de distance of travel.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
How about the color display like the CAE post result? Do you know the methodology ?
