Is it possible to display a dimension size as fraction in NX ?
Hi Team,
In NX 10 the dimension that i have created displays the dimension size in decimals. I would like to display the dimension size in fraction. Is it possible ? If it is possible  How could i do it ?
Raghav
Raghav
Re: Is it possible to display a dimension size as fraction in NX ?
Dimension settings -> text -> units -> change the "numerical display" option and "fraction denominator" options to what you want.
