Is their any Command (tool) same as frame in solid edge for NX?
I was working on solid edge from past 3 year i am very familier with its tools. Now i am working on NX for same design.
most of command are found same as Solid Edge in NX but i am looking for Frame Command in NX.
Solid edge frame provide simless tool for create Frame. If any plug in or tool same work as Frame please let me know.
or any other way to create Frame give me tool name as how to use in nx.
4 REPLIES 4
Re: Is their any Command (tool) same as frame in solid edge for NX?
Hi @Ceat_Halol_ED ,
mechanical routing license is required.
Thank you...
Using NX1867
RuleDesigner PDM
Thank you@cubalibre00
we have Mechnical routing Licence but i don't know how to use it?
Do you have any suggetion to learn this command?
Thank you so much for reply.
Hi @Ceat_Halol_ED ,
This documentation link will be helpful to you: https://docs.plm.automation.siemens.com/tdoc/nx/12.0.2/nx_help/#uid:xid1128417:xid1128430:index_rout...
Also this post might be of your interest: https://community.plm.automation.siemens.com/t5/NX-Design-Forum/How-to-create-Frame-design/td-p/3743...
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
Hi @Ceat_Halol_ED ,
apart the help, I suggest you a course.
You can buy a book.
You can use the Siemens PLM online course called 'Learning Advantage' (need a license).
See youtube.
Thank you...
Using NX1867
RuleDesigner PDM
