Is there a Way to Batch Export JT or Step Files
I'm fairly new to NX, but we use NX 9 and 8.5. Is there a way to batch export files as JT and/or STEP files from NX? We export the main files from Assemblies (parent files), and currently have to do this manually by opening each file and exporting as each file type. We do not use Teamcenter.
Re: Is there a Way to Batch Export JT or Step Files
For STEP under Start->Siemens NX 9->Translators there is a command for STEP import and export which allows you to select files from the OS, will then run the translators in the background.
Steve V
Thank you, I will give that a try.
For JT there is a command line command utility ugtopv
http://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help/#uid:index_nxtojt:xid487327:xid489796
Steve V
Is there a way to get to this ugtopv application? Sorry, but I'm too green to jump to this yet on my own.
Best to call from NX command prompt window, which you will find in Start->Siemens NX -> NX Tools
http://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help/#uid:index_nxtojt:xid487327:xid489074
Steve V
