Is there a posibilty to change the background color in NX to an Image or text
We are busy to configure IP Classification. Users with IP classification can edit or create IP Classified parts. We can block all export options, but we still can take a picture of the screen. Is it possible to change the background in NX with text, or using a image with text?
Thijs Janssen
5 REPLIES 5
Re: Is there a posibilty to change the background color in NX to an Image or text
Hi @weirnx,
Yes, you can.  However, most users will likely know how to prevent the background or text from displaying.  Have you considered using PMI?  Take a look at the following Security Marking section of the NX "Product and Manufacturing Information" documentation.
Regards, Ben
Ben,
Thanks for your input. We will consider this option. But it's not what i meant. We are looking for a background like a stamp on a PDF file. The text or image shout be transparently. We'd like to secure the print screen or making a picture. If there is a text present in the background, the print screen or photos has also the text visible.
Best Regards,
Thijs Janssen
I would focus on blocking print screen through windows.
Thanks **bleep**.
Probably this means there is no option in NX. Blocking the print screen through windows, means that all printscreen software should be removed etc. Taking a picture is still an option.
Hopfully Siemens will create an option to do this in the future.
We, Siemens PLM, also have a partner who can help control that using data using digital rights managment.
A summary of their offerings can be found here.
Digital Rights Management
If you need more information please contact your sales rep.
Scott
