Isometric View placing in drawing causes "invalid output" ?
Hello
Isometric View placing in drawing causes "Invalid input" ? (Base view)
  • What is the problem in this part ?
  • I can't place the isometric view to a drawing. Why ?
Re: Isometric View placing in drawing causes "invalid output" ?
In your model How is the model view isometric showing?
Your drafting views are place based on the model views.
Are you working master model of not?
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
It will be a bit difficult for us to comment without having access to part but can you check if the model view (isometric) works fine in Modeling also?
Else you can double click the Isometric view in modeling (so the view sets in the isometric alignment) and then add this as a new VIEW in Model views (right click the Model Views and use ADD VIEW).
I
If nothing works for you please contact GTAC.
Kapil
sorry.. i sent the same response twice.
I closed all parts and restarted the NX. Now works.
