Re: JT creation on save
just found out myself:
https://docs.plm.automation.siemens.com/tdoc/nx/10.0.3/nx_help#uid:index_nxtojt:xid618441:xid618449
_____________________________
Are you familiar with my product?
click here
thanks...learnt a new thing
In JT2go I got it working to show the explosion in a seperate View ! Smiley Happy
Now the real intersting question is: does anyone know how to further export this PMI Info (the exploded view) into 3d pdf format.
I usually get good results in converting JT to 3dPDF with Tetra 4D (assemblystructure remains intact)
Is there further functionallity that allows such a "rich conversion" including the PMI that anyone knows of?
click here
Just got it working:
this BOX needs to be checked during the conversion, niceley integrated then into 3Dpdf
click here
By the way,
is it possible to save a custom view and include a specific arrangement in there?
With explosions this works, with arrangements I am not sure how to do this
Greetings
click here
Hello everybody
I am now back at this point where I'd like make certain customizations at the  *.config file. During the "save JT" process, where does NX look up the "valid" *.config file? What is the rule or default location for that?
Greetings
Marco
click here
Marco, here is how it works.
JT Config File
Scott
thanks a lot, I had this in mind and therfore copied a tess.config file into my working directory (I assume that this is the location where the actual prt work data lies) however the JT creation on save seems not to respect that .config file, instead it will use configs from somwhere else.
Is there any means to track back which config file is being used?
Greetings
click here
If you don't have the UGII_PV_TESS_CONFIG_FILE variable set, then more than likely the tessUG.config file is being read from the default location as defined by the PVTRANSUI_DIR variable.
To be 100% certain, open a part containing a solid body and turn on the "Save JT Data" Save Option (File > Save > Save Options).  Save your part and then search your log file (File > Help > Log File) for "tess" and you should see the following at the bottom of your log:
Looking for config file: C:\Program Files\Siemens\NX 10.0/pvtrans/tessUG.config .... Found!
Regards, Ben
Dear Ben
I have tracked back via log file, and indeed it says:
Spoiler
Looking for config file: tessUG.config
Looking for config file: tess.config
Looking for config file: C:\Program Files\Siemens\NX 8.5/pvtrans/tessUG.config .... Found!
so 3 locations are beeing watched, only in one there is match... from what I can guess now
Still I observe different behaviour by "creation on save" than via "export-JT"
For instance attributes are missing when created on save.
I consulted the documentation various times, still I am unsure how to configure properly.
My Goal is the following behaviour:
  • Have NX write JT files every time I save (only for modified parts if possible)
  • JT files and assemblies having the same structure and relation as in original NX part data
  • JT Parts and Assemblies containing all Attributes that are found in original .prt data
Is it technically possible to get this behaviour by using the right configuration? Siemens Hotline is involved as well and I will post Solution as soon as anything is known, still greatfull for other advice.
Marco
click here
