Re: JT creation on save
there are a few threads that are concerning me a bit:
http://www.eng-tips.com/viewthread.cfm?qid=278687
http://www.eng-tips.com/viewthread.cfm?qid=352608
_____________________________
Are you familiar with my product?
click here
One more question on the *.config file:
What configuration do I have to set in order to create assembly jt's? (Meaning JT's contains the asy structure and other jt's are components in that)
Every possible option  I have tried only leads to JT's containing geometry of the actual part (none in case of an assembly) and no assembly structure with further jt components in it.
I know that this is possible since the Export JT routine can do it. How to achieve the same result with Save Option: "Sace JT Data" ? via the config file?
click here
To be more specific:
I'd like to set up  my *.config in a way that the "Save JT" creates the same result as "Export-JT" with the following options.
How to do this?
click here
