Library for Gear in NX
Dear all,
Where i can find a library for Gear in UG NX?
Thank !
Re: Library for Gear in NX
In NX8.5 there is a Mechatronics Concept Designer directory in the Reuse Library that has gears. I would think Siemen's wouldn't remove that in NX10.
There is an existing gear GRIP program for creating your own gears. I would recommend calling GTAC to have them send it to you if this would be helpful.
Attached is a zip file contains gear programs in both GRIP and User Function.  If you have problems uploading the file, send me an email and I'll provide you copy that you will be able to download.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Dear All,
I done it and make sucess, thank everybody
Hello Nguyen
I know you are Vietnamese. I am too. Could you help me with Nx? I have a few questions about the gear stuff. Im looking forward to hearing from you. Here is my email if you don't mind contacting me:
**NOTE**This post has been edited to remove private contact information. Thank you.
I'd advise against putting your private email address in the forum posts.
You can send other users in the forum a private message, that way only they get to see private information. Just click on the users name and on the page that opens click "Send this user a private message"
Production: [NX8.5.3.3 MP11 64bit] Testing: [NX12.0.0.27 MP1]
Community Manager
Hi @cadcam,
@Inch is correct. You shouldn't post your contact information anywhere on the community, as it is a public forum. It is actually against the community rules. This is just to protect you and your privacy.
Sending a private message is the correct way to share your information in order to take things offline.
Thanks!
Amy Allen
Product Engineering Software
Siemens PLM Software, Inc.
Community Manager, Solid Edge
Rules of Participation | Become a Guest Author
Become a Solid Edge Certified pro today!
Gears Legend Gears Legend
Gears Legend
Hi John,
Is there some kind of documentation to this macro?
BTW thanks for your great support over all those years, on the fora and also during Beta in Cypress.
Greetings,
Frank
Huysmans Metalen n.v.
2x NX 11.0.2.7 Mach Designer
on Win7 64bit
NX Beta Tester with focus on Sheet Metal
Command Finder is your friend
No, that's all I got from the people who created the programs originally.  They were never official 'products' so no one ever wrote any documentation for them.  However, if you understand the details of gear design the input parameters are fairly obvious as what is expected.
Irvine, CA
