Lift up button
Two project in one I can lift up the buttons and in the other it do not work, tried to copy the settings but no succes.
There it works I see the attached object but not in the other(pics)
Someone with an idea what to do
4 REPLIES 4
Re: Lift up button
Same issue here too. Some help is appreciated.
Thanks in advance.
Shane.
Re: Lift up button
I see that there is an operation created, how can I view operations
Re: Lift up button
I solved it, create operation (see pic) if I could get it in the thread
Re: Lift up button
Se pic solution
