Line Color Compensation for Light Colored Backgrounds
I am having issues with light colors on light backgrounds in NX11. I have been using NX11 for a while, but something changed today and all my light line colors are very difficult is see.
If you review the attached file, it shows how NX9 is changing the light colors to be more visible on a grey background. I want to replicate this in NX11 and cannot figure out what setting I need to change.
Any help would be greatly appreciated, as I have 10+ years of files that have all become incredibly difficult to use. (FYI I use the light colors because they make it easy for AutoCAD users to see when I translate to DXF)
~Kaiser
Re: Line Color Compensation for Light Colored Backgrounds
did you use the same ugcolor.cdf in both ?
Hi Maurizio,
Yes they are both the same .CDF file, provided by my employer in the install.
Search for "wireframe contrast" in the command finder and turn this option on.
That worked! Thanks so much cowski!
Perhaps this will help.
Best Regards
Kapil
Sorry...please ignore my post...didn't refresh my page before sending the reply...just saw Cowski has already shared the solution.
Best Regards
Kapil
