Line weight not shown when drafting sheet is printed out
Hey all,
When I am drafting in NX10 and taking a print of the sheet, I am unable to see the line weights I used on the drafting sheet in NX on the hardcopy.
Please could anyone help me know what needs to be fixed?
Thank you
Naga
8 REPLIES 8
Re: Line weight not shown when drafting sheet is printed out
Are you using
- File -> Print?
or
- File -> Plot?
2 different technologies, with (possibly) different solutions
In NX8.5, there is also File/Export/PDF, then print...
I am using File --> Print
I tried exporting to  PDF and printing too.
Even then the components with a line weight of 0.18 are also shown as 0.13 in the hardcopy.
Take a look at customer defaults
Gateway -> "Printing (Windows only)" -> "General" tab
Note the list of "width scale factor"s - I'm guessing this has something to do with your issue.
I have tried that too.
I have set it the same way it was on my NX8.5.
The sheets print with widths when I use NX8.5 but not NX10.
Use - File -> Plot
and there change in Manual settings of width: Normal = 0.6mm? thin = 0,18мм and thick = 0.8mm
Сhannel for NX users (Russian language) https://www.youtube.com/channel/UCvf0Rp4Sy6bRRyTYBF9rnJQ
I tried to do that now.
The drawing sheet in NX gets updated with the changes I do, but not the hardcopy. Hardcopy constantly gives only 0.13 weight lines irrespective of the settings.
