Linked Body not showing up in Exploded view
I am using NX 10 to create an assembly model consisting of various sub-assemblies. On this top-level model, I am using the Wave linker to promote a body of a subassembly in order to add some tapped holes on this body. Then, I had to hide this body in the sub-asssembly in order to see the tapped holes on the top-level assembly. Then, I tried to explode this sub-assembly with the added tapped holes, but this it where I got stock. The promoted body of this subassembly which contains the tapped holes,  remained on its original position, while the rest of the sub-assembly became exploded. Could some explain to me how to explode a sub-assembly model which contains bodies that have been promoted (Wave linked)?
Re: Linked Body not showing up in Exploded view
it's better to make a sub level on the parts where you want to create the tapper holes.
Exploded view is not really moving a component like the move. its a temp view position of an assembly.
that's why the linked bodies aren't moving in the exploded views.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
