List Through Curves
Does anyone know why the list option does not appear in the command? duvida.JPGduvida.PNG
Re: List Through Curves
Right click the gear icon on the top left of the dialog and see if you have the option "Show Collapsed Groups". Choose the option to see if it restores the list.  If that doesn't work hit the dialog reset icon on the top right of the dialog.
Regards, Ben
Click on the gear icon (to the left of "through curves" in the title bar of the dialog) and choose "show collapsed groups".
Edit: @BenBroad was faster on the draw this time...
Thank you guys!
problem solved!
