Load option, to open "precise" like?
Honored Contributor
Honored Contributor
Using Teamcenter 11.
User wishes to open an earlier revision of an assembly, just as it was saved, and NOT with the more recent components.  The assembly was NOT saved precise, since we typically do not work that way.
User has tried changing the assembly load options, File, Assembly Load Options..  to "precise only" instead of "latest working", with no luck.  Would changing it in the File, Open dialog work different?
Is there a way to do this?  Something tells me you can, but the how is slipping me.
Thanks.
-Dave
NX 11 testing NX1847+ | Teamcenter 11 | Windows 10
4 REPLIES 4
Re: Load option, to open "precise" like?
Would "Load As Saved" in the NX Assembly Load Options work?
Regards, Ben
Honored Contributor
Honored Contributor
@BenBroad "load as saved" isn't an option in the revision rules, we're working with Teamcenter.
-Dave
It's in the Top Dropdown.
Honored Contributor
Honored Contributor
@joewhite  I think that's what I was looking for, thanks.  I'll pass that on to the user.
-Dave
