Local Grid lines for drawing view
Hi All,
Is there any way of getting grid lines /work lines in the drawing view(Lines only to the view).
I could get the default grid lines which is covering entire sheet.
Devaraj
5 REPLIES 5
Re: Local Grid lines for drawing view
Honored Contributor
Honored Contributor
At a previous employer, we had some components, that were just a grid pattern.  You could add something like that to various layers, and turn on/off in the views, as needed?
-Dave
NX1867(if it had versions) | Teamcenter 11.6 | Windows 10
Hi @Devraj_Mendon,
No. There is no setting available to show grid lines in a drawing view.
What is your purpose? Some other option or workaround can be suggested based on your actual requirement.
@GaneshKadole,
 Currently im working in a project where I have to show X and Z values in grid line manners. This can be done in Catia.
Close to @DaveK suggestion, a workaround can be
  • Create a datum plane
  • Show datum plane grid with respect to WCS (or as you required)
  • Move grid to some layer
  • Create drawing views and use visible in view to show/hide datum plane grid in specific view(s)
(view in My Videos)
Perfect!!!
Thank you @GaneshKadole@DaveK
(view in My Videos)
(view in My Videos)
