Locating part in Constraint Navigator?
Hello
While working in Nx 11 assembly, often we are manually uncheck the constraints and finding which part(s) is loss degree of freedom and by which direction either rotation or by translation.
So is there any way check this automatically or by using options.
thanks in advance
Re: Locating part in Constraint Navigator?
Hi @Thilagaraj,
Do the object information (Ctrl+I) on component, Information window will display related constraint information.
eg. - There are 1 rotational and 1 translational degrees of freedom.
To know the exact DOF direction(s), you will need to select component from UI > RMB > Show Degrees of Freedom.
