Log files
What does those attributes in NX Log Files mean?
-PH
-PRH
-RT
-AT
Re: Log files
Can you provide your log file, or the portion you are referring to?
Re: Log files
PH and PRH are the UID's of the Item and Item Revision in Teamcenter.
RT and AT are the PDI reltype (RT) and PDI apptype (AT):
Part file type
PDI reltype (RT)
PDI apptype (AT)
master
"has shape"
"UG master part file"
specification
"has specification"
"UG part file"
manifestation
"has manifestation"
"UG part file"
altrep
"has altrep"
"UG alternative rep"
Regards, Ben
