MOUSE WHEEL ZOOM IN & ZOOM OUT
Hello all,
Here i want to change my mouse wheel direction the opp way..but i am unable to find the option in customer defaults in NX9..but when i checked in NX11 the option was there as well as NX10.
Is there a way to change my zoom in & zoom out options for NX9?
5 REPLIES 5
Re: MOUSE WHEEL ZOOM IN & ZOOM OUT
Hi @karthik6,
No. (In Customer Defaults)
It was the enhancement introduced in NX10.
Zoom operation enhancements
EDIT: I forgot about the environment variable which is suggested by @PhoeNX_Support . Just to mention, it was introduced in UG NX 2.0.
Ganesh Kadole
This can be accomplished by setting an Environment Variable in the Windows
Control Panel.
The variable name is UGII_MOUSE_WHEEL.
The usable values for UGII_MOUSE_WHEEL are:
Undefined - Same as UGII_MOUSE_WHEEL=1.
0 - Disables the mouse wheel in the graphics window. Does not affect its
behavior elsewhere in NX or in other applications.
1 - To zoom in, scroll the mouse wheel toward you; To zoom out, scroll away
from you. The default.
2 - To zoom in, scroll the mouse wheel away from you; To zoom out, scroll
toward you.
Anthony Galante, Senior Support Engineer
PhoenxPLM
24 versions of NX installed: NX4 to NX12, plus TC11.2
Thank you for your support Smiley Happy
Control Panel.
toward you.
Control Panel.
toward you.
Thank you ganesh Smiley Happy
BTW, the reason that the Customer Default was added in NX 10.0 was because they changed the default 'zoom' direction so as to make NX more consistent with the rest of the known universe.   Of course, the purpose of the customer default was to give an opportunity for those who just can't live with the rest of known universe, to go back to their comfort zone Smiley Happy
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
