Make Attibutes in Assembly level inherit the values of the part
Hi, I'm having an issue. I have an assembly and some attributes like the length of a part where modified there, now, they are no longer updated when I modify the part. How can I make does attributes inherited again?
Re: Make Attibutes in Assembly level inherit the values of the part
Did you try to right click on the tag symbol.
If i'm right there will then be a option delete
This will recover the link normaly.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
No, I though that that would erase the attribute and I didn't try.  Lots of thanks.
