Make Leader Stub Side Selection Sticky
I want to change the leader stub on the 133.6 dimension to the opposite side of the dimension.
When I select the Leader from Left option, the dimension moves as shown below.
But when I drag the dimension back to where I want it, the leader jumps back to the right.  Is there any way to make the "Leader from Left" option stick?  Thanks.
Re: Make Leader Stub Side Selection Sticky
Hi @DaveL3149,
Hold down the Ctrl key while you drag the dimension.
Regards, Ben
Thanks again.
