Make a two object parallel with some distance
How to make a.JPGhis two body as parallel with  some distance in nx assembly .
Re: Make a two object parallel with some distance
you can use the Parallel assembly constrain and a distance constrain to make it in a good way
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
HI @S7
I think you need to learn constraint. In your case it's distance constraint to assemble two component.
below video link may help you, Additionally you can check his channel for more assembly constraint.
https://www.youtube.com/watch?v=QJ60SHLgNyI
Hope it helps.
:Smiley SurprisedPTIMUS_PRIME
::Smiley SurprisedPTIMUS_PRIME
