Measures and Crosshatch in drawing ?
Hello
Why some measures are highlighted(green) and some are not(red) when Crosshatch is used in drawings ?
  • I want all to be highlighted for easier readability.
Re: Measures and Crosshatch in drawing ?
did you checked the crosshatch what is and what isn't selected to trim the crosshatch to
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
Hi @12131444,
As @ruud_vandenbrand suggested, Edit the crosshatch and select the required dimensions/annotations for the option 'Annotations to Exculde'.
Ganesh
Ok. I clicked On/Off "V Set Margin Individually"
  • Worked
