Merged Bodies Volume will be same or not
Hello
I am working in a huge assembly for inner flow volume calculation.
I created more inner bodies for my product, and i found in some places some parts are merging. When i caculated the volume Nx skipped the merged volume and gave only the correct required volume.
I really surprised is this a Nx behaviour, or i made any mistake.
Please confirm me. Thanks in advance.
Sekar
6 REPLIES 6
Re: Merged Bodies Volume will be same or not
Hi @Sekars ,
Can you please add a snapshot of part with measurement, if possible?
Samadhan
GTAC | NX Help: NX1102 | NX1202 | NX1847
Please mark post as an "Accepted Solution", if it answers your question/is more helpful!
Hello Samadhan
Thanks for your post, Sorry it is not possible now.
Very simple,for example if a 2 cylinders is there then, both volume is say 500 units (250+250), but if both merged for some length and for that length only one cylinder volume calculated (another one cylinder volume ignored) so total will be 400 units.
Thanks again
Sekar
@Sekars ,
If it is below scenario, then it seems to me working correctly.
(view in My Videos)
Samadhan
Hello Samadhan
Thanks for the video
First make any one cylinder lenther so that it will merge / interference with another cylinder.
Then make them as Body by using Remove parameters, then we need to measure this,
I cannot do this since i am working in TcE Nx (not Native Nx)
Thanks again
Sekar
I think Unite body or non-parametric body will give the same result. Can you check that?
Samadhan
Hi Sekars,
You need to provide more detailed information. I just did the same test as Samadhan. Do you mean to Unite the bodies or are you analyzing them all together still interfearing?? I would assume that a unite will be in place and give you the correct answer...
Best Regards
Fred
