Merging multiple convergent bodies/facets
What is the most efficient way of merging multiple convergent bodies/facets from a 3D scan?
the following commands only handle 2 convergent bodies/facets at a time
"Merge disjoint
Merge overlapping
Merge touching
1 REPLY 1
Re: Merging multiple convergent bodies/facets
Hi AlexLee,
Here's a simple trick for you. Export all your convergent bodies that acc to you image aligns nicley to an STL-file. Import that STL-file back into NX as a convergent body and use Automatic Cleanup. See attached picture.
I hope this helps you.
Best Regards
Fred
