Middle mouse can't rotate geometry
When i button Middle Mouse, i can't rotate geometry, i try to change new mouse but i can't rotate
4 REPLIES 4
Re: Middle mouse can't rotate geometry
Can you scroll using the midddle button?
Kapil
Siemens Legend Siemens Legend
Siemens Legend
I would check to see that your mouse driver is the latest one. I have not seen that behaviour before.
Paul
In addition to @Paul_Bevan's driver suggestion, try a different physical mouse. It may be that your mouse is broken or faulty.
It's quite common that people buy gaming mouses which comes with special drivers where the individual button can be programmed to do something special ( i.e fire a torpedo or soething.) frequently then the basic mouse functionality "Middle mouse button" has been remapped to something else.
If this is the case, open the mouse driver software, select action for the middle mouse button, set it to "middle mouse button".
 Tomas
