Missing a part of drawing view
Hi all,
When I export Drafting to PDF file. A part of Drawing view is missed. Maybe the front drawing view covers the back one. Anyone know how to make transparent the boundary area of front view to fix this problem?
Re: Missing a part of drawing view
在制图里需要把视图分开,不要重叠起来。
It is a known issue with no fix so far (that I know of).
If just the border areas are overlapping you can try using commands at the PDF level.
This will not fix the issue if the images are overlapped.
In the PDF RMB > Edit Text & Image; LMB double click on border (either will work) > RMB > Arrange > Bring to Front (or Back).
Hi @Henry_Ha,
It is a limitation in this case. Please refer section 'Plotting Shaded Views' from this documentation link "General usage notes for shaded drafting views".
A workaround (Depending upon your actual requirement) can be to export drawing region as JPG and then print this image as PDF. But there will be considerbale difference in terms of quality, line width etc.
Ganesh
