Model Views - How To Delete
NX10.0.2.6 MP1 -> Modeling -> Model Views:
I have a recurring issue with Model Views being placed in my work layer while working in the Modeling environment.  I am unable to delete or rename these Model Views.  Has anyone had this issue and found a way to delete these views?
Re: Model Views - How To Delete
Right click the view and choose Properties. Select the General tab and then select the Information icon. The Information window will open and list details about the view which may give you an indication why it cannot be deleted. If you post the content here we might get a better idea of why you can't delete it.
Regards, Ben
Ben,
Here is the information log file for one of the model views:
Information listing created by : -------
Date : 6/1/2016 12:16:48 PM
Current work part : -------
Node name : -------
Information on object # 1
Name TCP_PNTS_LAY_13
Owning part ------- (SAME AS CURRENT WORK PART)
Modified Version 91 12 Jul 2013 12:29 (by user -------)
Created Version 91 12 Jul 2013 12:29 (by user -------)
Object Dependency Graph:
Modeling View - TCP_PNTS_LAY_13
Used by:
None
Displayed: No
Is Member of View Set: No
Orientation Association: No
Valid Association:
Origin Association: No
Valid Association:
Visible Layers Global
1-2,8,10-14,50-52,201
Front Z-Clipping = 2.49573019052
Back Z-Clipping = -2.49573019052
Display Scale = 5.50703956986
Center XC = -214.59786338475 X = 0.00000000000
YC = -8.72598344373 Y = 0.00000000000
ZC = 146.21152848533 Z = 0.00000000000
Drawing Reference XC = -214.59786338475 X = 0.00000000000
Rotation Matrix
X-axis Vector XC = -0.07954323704 X = 1.00000000000
YC = -0.66212939714 Y = 0.00000000000
ZC = -0.74515604734 Z = 0.00000000000
Y-axis Vector XC = 0.99435076371 X = 0.00000000000
YC = 0.00000000000 Y = 0.00000000000
ZC = -0.10614404698 Z = 1.00000000000
Z-axis Vector XC = 0.07028109384 X = 0.00000000000
YC = -0.74938952584 Y = -1.00000000000
ZC = 0.65838887172 Z = 0.00000000000
Perspective Distance Off
Camera TCP_PNTS_LAY_13
Thanks for the quick response!
Nothing unusual there...
What happens if you select the custom view and hit the delete key (make sure it does not have "(Work)" next to the view name)?
Regards, Ben
Spoiler
I get this error:
Based on that error it looks like you have pre-V13 sketches in your part. You will not be able to delete the sketches or the views, or rename the views. Since your views show "_0" and "_1", I'll assume your imported a part into your current part multiple times. The part you imported is probably an old part and is the culprit that has the pre-v13 sketches.
Regards, Ben
These views are created by an NX add-on that was developed by our company so this seems to be an issue on our end.  Thanks for the advice!
