06-01-2016 11:20 AM
NX10.0.2.6 MP1 -> Modeling -> Model Views:
I have a recurring issue with Model Views being placed in my work layer while working in the Modeling environment. I am unable to delete or rename these Model Views. Has anyone had this issue and found a way to delete these views?
Solved! Go to Solution.
06-01-2016 11:59 AM
06-01-2016 12:25 PM
Ben,
Here is the information log file for one of the model views:
Information listing created by : -------
Date : 6/1/2016 12:16:48 PM
Current work part : -------
Node name : -------
Information on object # 1
Name TCP_PNTS_LAY_13
Owning part ------- (SAME AS CURRENT WORK PART)
Modified Version 91 12 Jul 2013 12:29 (by user -------)
Created Version 91 12 Jul 2013 12:29 (by user -------)
Object Dependency Graph:
Modeling View - TCP_PNTS_LAY_13
Used by:
None
Displayed: No
Is Member of View Set: No
Orientation Association: No
Valid Association:
Origin Association: No
Valid Association:
Visible Layers Global
1-2,8,10-14,50-52,201
Front Z-Clipping = 2.49573019052
Back Z-Clipping = -2.49573019052
Display Scale = 5.50703956986
Center XC = -214.59786338475 X = 0.00000000000
YC = -8.72598344373 Y = 0.00000000000
ZC = 146.21152848533 Z = 0.00000000000
Drawing Reference XC = -214.59786338475 X = 0.00000000000
Rotation Matrix
X-axis Vector XC = -0.07954323704 X = 1.00000000000
YC = -0.66212939714 Y = 0.00000000000
ZC = -0.74515604734 Z = 0.00000000000
Y-axis Vector XC = 0.99435076371 X = 0.00000000000
YC = 0.00000000000 Y = 0.00000000000
ZC = -0.10614404698 Z = 1.00000000000
Z-axis Vector XC = 0.07028109384 X = 0.00000000000
YC = -0.74938952584 Y = -1.00000000000
ZC = 0.65838887172 Z = 0.00000000000
Perspective Distance Off
Camera TCP_PNTS_LAY_13
Thanks for the quick response!
06-01-2016 12:57 PM
06-01-2016 01:07 PM
06-01-2016 01:52 PM
06-01-2016 02:09 PM
These views are created by an NX add-on that was developed by our company so this seems to be an issue on our end. Thanks for the advice!
