Re: Model looks hollow
Edit ->  Object Display, change the type to Face and select the transparent face.
It maybe that somehow it's been set to be translucent.
Anthony Galante
Senior Support Engineer
PhoenxPLM
The best way I know to check that your part is just one solid body is to right-click in the background of the Part Navigator and turn off Timestamp Order.
A quick way to look at the solid model is to use a rendering style of Wireframe With Hidden Edges.
Is it possible that you selected that face and made it translucent?
I agree with those who attribute this to a transparent face.
Are you running a computer with a certified graphics adapter, and a certified driver ?
https://www.plm.automation.siemens.com/en_us/support/gtac/#lightview%26url=/en_us/Images/Graphics_Ce...
Tomas
Honored Contributor
Honored Contributor
I've had a bad feature cause a single face to look "hollow", but this was years ago.
-Dave
NX 11 testing NX1847+ | Teamcenter 11 | Windows 10
Did you already try window select or CTRL+A all faces and re-apply a new color and shading?
Also make sure you do this when the concerning parts is the "displayed part" or "Isolate in new Window" (= displayed parts NX12 onwards)
How a part is shown can be assembly specific.
2018-03-20_02.gifedit object display
Huysmans Metalen n.v.
2x NX 12.0.2.9 Mach Designer
on Win10 64bit
NX Beta Tester with focus on Sheet Metal
Command Finder is your friend
Hi MicheIL,
Your issue is most likley due to that you have made a downstream feature or face trasparent together with the Modeling Preference "Display Properties for New Geometery" set to Tool Body. Have a look to the attached video for
(view in My Videos)
details.
I hope this helps
Best Regards
Fred
Thanks for all the sugestions but I still haven't found the solution.
I have tried all the mentioned options and still don't know what it is.
Attached the file of it.
With Extrude(2) as current feature or the last one in PNT, there is no problem for me so that at any step it will look hollow.
Same here; no problems
on Win10 64bit
