Modeler Error Message
I keep getting an error message:  Error occured during display of part
Modeler error: modeler error: please report fault.
I click the okay button and I model seems to display fine, is there any way to diagnose this error message further to try and correct the error?  I've attached a screenshot of the error message, but not a whole lot of info.
Re: Modeler Error Message
Reproduce the error and then select:  Menu > Help > Log File
Upload a copy of the syslog.
Regards, Ben
Here you go - any assistance is appreciated.
Was this part created from scratch in NX?  If not, where did it originate (from which product)?
If you execute "Menu > Analysis > Examine Geometry > Set All" on this part, do any of the fields fail with the option "Highlight Results"?
Ben
No errors.
You didn't answer the following question:
The problem is a Parasolid rendering issue. I would give the GTAC NX CAD support group a call and be prepared to provide your log file along with your part file.
Regards, Ben
Sorry - yes the part was created natively in NX.  We used customer geometry that was created in NX to develop tooling to manufacture the part.  The only imported geometry that is non native would be hardware items that were downloaded as step files and imported into NX, but these same hardware items are used in other tools without any issues.
Thanks for your assistance.
In that case I would definitely report the problem to GTAC.
Thanks, Ben
