Modeler error occurred when updating hidden line display.
Hi
I am getting this error (Modeler error occurred when updating hidden line display.)
Please let me know how to fix this, This is happening while updating the exploded view.
Abhi
Re: Modeler error occurred when updating hidden line display.
Hi @Marni,
Based on the Update event list, your exploded view "TRI-EXPLD" is having a rendering issue - hence the modeler error updating silhouettes.  How does the view look if you go into the Modeling application and replace the view to TRI-EXPLD?  Do you see the silhouettes?  Does the part shade correctly?  Try the Rendering Style "Wireframe with Hidden Edges" - does that render correctly?
For the quickest solution to this problem I would suggest calling your local GTAC support office, who are familiar with resolving these types of issues.  Otherwise, I would probably run Examine Geometry to ensure that you don't have any self intersections or data consistency issues with any of the parts, and also a Part Cleanup.
Regards, Ben
