Modeling a CAM
I'm using NX8 and I want model a CAM like the attached file.
Which is the best workflow to simulate a real CAM operation ?
Thank you...
Using NX1859
RuleDesigner PDM
Re: Modeling a CAM
I modeled this a while ago in NX 5.0. You can move the component of the milling tool, too.
Still works, but is not as cool as a swept solid, which is not yet in NX.
Your use case shoul dbe easier, as you don't have to model the floor of the groove.
Johannes
