Mold wizard library problem
Hi, everyone!
Library of standard parts in NX 10 in mold wizrd doesn't work. How I can install it?
best regards
Re: Mold wizard library problem
Hello
The MW standard parts library is a seprerate install than NX. After installing you should see all the MW specific items in the re-use library.
Here is the link to the readme.
Here is the link to the library.
Best Regards
Paul
