Motion Simulation with Rack fixed
Dear Experts,
Is there a Rolling type of motion possible in NX? If so how?
I am looking at simulating Rack and Pinion with Rack fixed.
Thank you Verymuch.
Prasad
Durgavajjala S.Prasad /NX 9,NX10&NX11
Re: Motion Simulation with Rack fixed
Siemens Legend Siemens Legend
Siemens Legend
How about using the Rack and pinion feature ?
Does that help ?
/ Tomas
I tried Rack and Pinion coupler, but I am able to select either slider or revolute joints, not both.
Please refer to attached image.
I am using a fixed rack,  a revolute (rolling) pinion and a slider support rod.
When keeping the support rod as base link for pinion, I am unable to select the created slider and revolute joints together.
(However, when base link is not selected, I am able to select both joints, but Pinion is then not rolling, just revolving.)
Please help.
Siemens Legend
If the model in the image, is the model, - Can you upload it ?
 Tomas
I am uploading similar model. I am missing where to use 3D contact,coupler,... Thank you verymuch for venturing out to help.
Finally, the '2-3 Joint Coupler' did the trick.
