Mould design
how to split the non planer part for making mould...i hereby attached one non planer part in .step format..
Re: Mould design
We use the draft analysis tool, and the contour lines to find a split line.
-Dave
Re: Mould design
can you share the workout video for this part..
Re: Mould design
It's just a bolt, but will give you the idea.  I had to zip, uploading the video as is failed.
-Dave
