Move Curve command
Hello!
I am just looking at the Move Curve (2D sync tech) command in Sketch. In the settings group, there is an option Keep Tangent, with two options: Automatic and Fix.
Can someone shows, what is the difference between those two?
I have create some simple examples like rectangle with fillets or line with arcs, etc. But on such geometry, automatic and fix gives me the same result.
Thanks.
Best Regards.
