Move PMI Freely
Hi there,
I'm having some troubles in PMI positioning, when i utilize PMI in an assembly, looks like the dimension get locked, and i can't organize as i want. As you can see in the video, all the PMI must be align, but, there are some restrictions and i can't move freely.
Unable to play video. Please try again later.
(view in My Videos)
(view in My Videos)
Re: Move PMI Freely
Hi @Juks10,
Hold down the Alt key on your keyboard and then drag your PMI dimensions.
Regards, Ben
Re: Move PMI Freely
I've already tried, but it doesn't work.
Smiley Sad
Re: Move PMI Freely
Maybe you're "Snapping to Grid".
Select "Menu > Preferences > Grid" and see if "Snap to Grid" is checked.
Regards, Ben
Re: Move PMI Freely
Your videos do not display, so it's hard to understand your problem. But there are two things that may be affecting the movement/alignment of your PMI dimensions:
  • When you create your PMI, make sure the Alignment options in the Origin group of the dimension dialog box are set properly. For example, if you want dimensions to stack properly, the Stack Annotation option should be set.
  • If you want to stack PMI annotation, it's imperitive that you create the annotation on the same annotation plane. In the Origin group, under Orientation, make sure the Plane option is set to the same plane (for example, set to XC-YC Plane).
Re: Move PMI Freely
Yes! Solved!
My assembly model was with "snap to Grid" checked!
Thanks!!
