Move part's coordinate in assembly ?
How to move part's coordinate in assembly ?
  • Make XC, YC, ZC aligned to the assembly's existing parts.
Re: Move part's coordinate in assembly ?
Ok I found it.
I used "Constrains" and "Touch align" to position each x,y,z vector.
Once you start the 'Move Component', use 'Specify Orientation' (Motion as Dynamic) to place CSYS at desired point and check 'Move Handles Only'.
Orient the CSYS with X/Y/Z axes direction as per your requirement and uncheck the 'Move Handles Only' option then move the component.
Ganesh
