Moving Bodies with Parent Constraints Failure
Hey,
I'm trying to move a body within a part and I get multiple warnings saying that while moving the part, sketches are "Missing positioning reference", "Unable to reference parent objects that are deleted", "Sketch contains conflicting constraints due to the edit", and "Unable to rederence parent objects that are either suppressed or modeled away". Anyone know how to fix this?
Re: Moving Bodies with Parent Constraints Failure
Probably going to be a wide range of guesses as to how to "fix" it if we can't see the part and how the sketches were constrained to the body. Can you not go into the sketch and see what references are missing or have changed????
Tim
NX 11.0.2.7 MP11 Rev. A
GM TcE v11.2.3.1
GM GPDL v11-A.3.5.1
