Moving *Create New* part inside assembly
Hello
I have created a new part inside assembly and try to move its DatumCSYS(origo) but this time it won't let me.
  • See picture below: where I try to move a *Create New* part's CSYS to a correct place.
  • It selects the component=Part but NX does not see its origo ?
  • Why this happens ? ( I usually succeed in moving but not with this one )
3 REPLIES 3
Re: Moving *Create New* part inside assembly
I used Dynamic Move first and after that Point To Point started working.
When you click in the dialog to active the selection to select the First point what snappoints filters are on in the top border bar?
And what is showing in the selection scope?
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
In cases like this where there is no real explanation of a dialog behaving unexpectedly, try hitting the dialog reset icon on the top right of the dialog (curly arrow icon).  This resets the dialog settings back to the out-of-the-box state.
Regards, Ben
