Multi-line text
Is there a way using the text command to allow for multi-line text?
Refering to the screen shot below, the text shown is three individual lines.
4 REPLIES 4
Re: Multi-line text
Hi @Mark-J,
This is not currently possible using "Curve > Text".
Existing ER 5535304: Unable to add multiple lines of text using "Insert -> Curve -> Text"
Regards, Ben
Re: Multi-line text
Thanks for the confirmation on this item Ben!
Glad to see there is an ER already in place.
Re: Multi-line text
Ok, guess I am still taking baby steps here. How can I find the status and be added to an ER if it is open?
My searches (ER 5535304) only came back with 4 discussions from 2010.
Thanks!
Re: Multi-line text
You cannot access ERs to see their status or what was requested.  Contact your local GTAC office and ask that they add you to the ER so that you are notified regarding any progress.
Regards, Ben
