Multiple materials for part, composite materials - mass,density
Anybody have worked with composite materials? Or used multiple materials for part?
For example we have one part/detail that must consist of 2 or 3 different materials. How can be assigned few materials for this part and then geted mass for this part?
Is Integrated Materials Management module resolve this task?
The task is interesting and not typical.
In common case we have one part and one assigned material (with density data) and this is enougth to get mass for this detail, i.e -  one part->one material, but what about one part  and multiple materials?
Re: Multiple materials for part, composite materials - mass,density
Hi @alex_c,
multi parts for part you mean multi-body in part. Said that, you can assign for each body a different matarial via assign material command. The mass is calculated well.
Thank you...
Using NX11 and NX1847
RuleDesigner PDM
You could also try menu->edit->feature->solid density and assign each body a specific density if you don't have the desired material available in your material library.
