NX 10 Single side Dimensions
Siemens Builder Siemens Builder
Siemens Builder
Hi all,
I want to include a sinle side dimension in a View Break ......
As the part has not a horizontal edge that I can use I do not know how to proceed....
i attach jpg files(I want get the single side dim. as show in Single_sided_dim_NX10_1.jpg
Thnks in advanced.
Re: NX 10 Single side Dimensions
If your view scale is 1:1 you can expand (Right Mouse Button on View) the view, create the dimension and turn the expand off. Now you can create your View Break and the dimension is still there.
When you have two views you can create your dimension between this two views. But for better handling you should create a relative position to your desired geometry with the Origin tool.
Regards André
Siemens Builder
Thanks a lot André
Regrads!
