NX 10
Hi, do you know how to install hel on line?
4 REPLIES 4
Re: NX 10
Hi @FrancescoB_1968,
You could start by reading nx-ugdoc-10.0.0.README.TXT.
Is there any reason why you can't use the Online Documentation provided by Siemens?
Regards, Ben
NX (v17 - 1876) | Teamcenter (9 - 12)
Re: NX 10
Siemens Legend Siemens Legend
Siemens Legend
Hi Ben,
do you know how to set NX to use the online help when I press F1?
Beppe G
Siemens PLM Italy
Re: NX 10
Hi @UGoverALL,
Try setting the UGII_UGDOC_BASE environment variable as follows:
UGII_UGDOC_BASE=https://docs.plm.automation.siemens.com
Regards, Ben
Re: NX 10
Siemens Legend
Thank You.
It works
Beppe G
Siemens PLM Italy
