NX 11.0.2: Mechanical routing. Stock dimension with decimals gets truncated to integers?
Hi all,
I have added some angle bars to my stock library via .ptb and .plv files but when browsing for stock info in the part navigator, I see that dimensions with decimals gets truncated into integers. Please find attached screenshot.
The radius dimensions should read 6.5 and 3.5. However, when measuring on the stock body itself, the decimals appear.
Is there any way to increase the number of decimals shown in the info window?
May I add that I have  Teamcenter 8 integration when running NX, and that i am using part families to add stock items.
Thanks for any clarifications!
2019-02-12 15_51_22-NX11 (NX Setup Bergen Engines AS Prod 30.09.2018) - Routing Mechanical - [B01037.png
Re: NX 11.0.2: Mechanical routing. Stock dimension with decimals gets truncated to integers?
Hi @Eirik_xyz
Take a look at your Customer Defaults and see what "Number of Decimal Places" and "Use System Precision in Information Window" is set to for Information Window:
Regards, Ben
Hi @BenBroad
Thanks for the suggestion. I tried to enable this option, but still no luck. System precision seems to be 11 decimals.
Anything is worth trying.
Eirik
Hi @Eirik_xyz
Repeat your steps by right clicking on the Stock feature in the Part Navigator and choosing Properties.  Review the Attributes tab - do you see attributes for r1 and r2 and if so, what are their values?
Regards, Ben
Hi @BenBroad
The values are still integers, unfortunately.
Regards, Eirik
Can you upload the ptb file?
Hi @BenBroad,
Sure. See attachment!
Regards, Eirik
Siemens Genius Siemens Genius
Siemens Genius
I'm going to guess that replacing the commas for periods for the decimal point is the issue.
Doug
That was it @Doug  - good catch!
@Eirik_xyz, you will have to replace the commas in your ptb files with periods for the decimal places.  You might also want to submit an ER with GTAC to request that commas be recognized in the ptb files.
Regards, Ben
Hi @BenBroad and @Doug,
This fixes the decimal issue!
By the way, I'd like to point out that attributes for a stock does not update once it's created. So if you change attributes in the ptb or plv file, only subsequently created stocks will have updated parameters.
This metadata thus seems to be static.
Thanks a bunch for all assistance!
Regards, Eirik
