NX 11 - What's New - Expressions
Check out this preview of the new NX 11 expressions system.
(view in My Videos)
Thanks for watching,
Scott
16 REPLIES 16
Re: NX 11 - What's New - Expressions
Hi Scott,
apart the new UI, it's better to post a video where you show the enhancements added. Enhancements that help designer to better use, manipulate and edit expressions.
Programm one year and half for a simple restyle, where you lack in scketch, assembly, sheet metal and drafting, it's appear a poor marketing operation.
Give to NX users the real benefit of this implementation with an interesting video.
Thank you...
Using NX1867
RuleDesigner PDM
Why do I get "Cannot Connect Server"
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
'cause you're not in the EU any more? Oh, no that's me isn't it...
Dell 7530 Precision, Win10, 32GB. Developing in: Java | C | KF
Production: [NX12.0.2 MP1]
Graham, Do you like not to be?
BTW I'm in NA!
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
Personally I think it was was the wrong decision. But thats all anyone can think about today.
Anyway this isn't really a political platform. Sorry to hijack the thread.
It works fine for me.
What browsers have you tried?
Mark Rief
Retired Siemens
Chrome and in Explorer it's blank. May be our Fire Wall is blocking it.
Michael Fernando
Die Designer
NX 11.0.2.7 + PDW
Hi Scott,
I've been using expression for quite some time now, upgrading to NX 11, MP 02 was good till I used expressions.
Seems like something is missed out; earlier upto NX 10 I was able to use expressions very easily but when I try the same expression in NX 11, it gives error & is unable to update wherein the same expression is working perfectly fine in NX 10, it also works fine with NX 11 if I just open the NX 10 file in NX 11 but it can't create that expression in NX 11.
I want to calculate the no. of holes for a pattern so that it updates automatically when user changes the length, I am using below exp:-
length - (hole_pitch * (no_of_holes - 1))
It gives an error & is unable to update, find attached snapshot for reference.
I am not using MP2, so if your results are different I would contact GTAC.
Your solution has to do with the units of the expressions. I change the no_of_holes to a constant and mine works as showing the image below.
Scott
