NX 11 Windows 10 Compatibility?
Hello. I'm sorry if this has been answered before, but for the life of me, I cannot find an answer.
Is NX 11 compatible with Windows 10? Where did you find that information?
Thank you!
Re: NX 11 Windows 10 Compatibility?
The release notes of NX 11, which are installed with NX contain this information.
I'm sorry, Stefan, but that really does not help me as I don't have NX 11 yet. This is part of my decision process.
You can find this information on the GTAC website. More specifically, it can be found on the hardware and software certification section, click on the "NX" link in the "NX certifications" section.
You didn't say what kind of access you have to further information.
  1. Do you have the NX install media, then you have access to the release notes, since they are contained in the docs folder on the CD or ZIP file.
  2. Do you have access to the GTAC documentation pages, then you can check the release notes there too.
  3. The GTAC solution center allows searching for the therm "Windows 10" and you get the information about supported software.
Thank you so much! I found the information, but I couldn't find it at NX Certifications. I went into the GTAC website, opened the Documentation tab on the left, scrolled to find "NX", and clicked on "NX Release Notes PDF"!
The release notes say:
"Windows 10 is certified for NX 10.0.3 and later versions including NX 11. Any caveats or special
instructions are provided in the SFB announcing support."
This is definitely the answer. Thank you so much, cowski1!
Here's some screenshots to help find the document I mentioned:
On the main GTAC page, click the following link:
This takes you to the following page that has the certification matrix spreadsheet:
You can access them from the GTAC quick Links at the bottom right too.
